Damaged Cross Shaft
Im in the process of installing an aussie locker in my rear of my fj and during the removel of the cross shaft I noticed alot of wear on 1 end where the spider gear spins on the shaft . I also noticed that the inside of the spider gear has serious wear on it as well. I'm not to sure what would cause that since it had lube in the diff and that seems to be the only wear like that in the whole assembly.
Does anyone sell the hardened cross shafts or do you think it would be ok to install the same one since the spider gears are being removed? Aussie says in order to warrenty there product the shaft must be of the hardened steel. Any thoughts?
Stroker
Stroker
