here's some food for thought:
I'm in a similar situation. I need new suspension. I am holding out for the right time to put OME on my FZJ cause I know it is going to ride sooo smooth. I am parking my FZJ for four months while I am out of the country - when I return suspension is happening like in the first two weeks!
Also, I am not sure if I want no lift or a very mild lift (like an 1" lift). Regardless, I plan to level out the body of the truck by adding an inch or so the front end of my rig when I change suspension because I like the level-look as opposed to the hood-down look. I may decide to go with that 1" lift to get a more squishy ride and better articulation and clearance for off roading with the planned 33" tires that will find their way onto my FZJ as well. Spend a little time deciding what you ultimately want is the key to making the right decision.
Here are three simplified ways to go:
simple, inexpensive option:
Call Cruiserdan in Parts at Amercian Toyota in Albuquerque New Mexico and order new OEM Toyota Shocks and Springs, install them yourself or have them installed.
more expensive, not so simple option:
call any one of the many shops that stocks OME suspension and talk to them about your needs. they will tell you which springs you need. chances are good the stock height, medium ride suspension kit is what you are looking for. get it installed or install it yourself.
most expensive, most complex option:
get a OME lifted suspension kit, requiring all kinds of additional hardware to make your truck steer nicely on the road (castor correction, CV, longer brake lines, etc). get it installed at your nearest hardcore TLC shop.
