CV Joint Driveline
Greenwood, CA.
Website
www.overalndwerks.com.com
I've build a few drivelines, just the regular kind so this weekend I shortened and modified a CV joint type driveline. I got so carried away welding the driveline togeather I did not take in concideration off-setting the yokes like you do on a regular driveline :doh:. The question is do I need to off-set the yokes and if so how should it be done. One end has the CV joint the other single u joint.
The Ears of the U joint should line up with the Ears on the CV side. same as with a non cv..
