Cutting the tunnel...
jackbrad
15 Year 10 Year
Charlotte, NC
Website
www.mattison-consulting.com
As some of you may read in other posts, I am replacing the engine and trans in my truck as the first step in my rebuild of my Fj40.
I am moving the engine and trans back to allow for the cooling fans.
I did the first run of the complete install engine, trans, and transfer case this afternoon. The whole thing is about 5'10" long, (4" taller than me) when installed the transfer case reaches all the way back into the truck to about 14 inches away from the rear end.
Because of the length, the tranfer case goes well beyond the original tunnel allotment for the transfer cases size. Meaning there is not space in the transmission tunnel for the transfer case.
During the install and mock up we noticed that transfer case was pressed all the way almost against the floor board. This also causes the transfer case driveshaft output to be lower than the input of the rear diff.
I see that I only have three options:
1. cut the trans tunnel and lift the transfer case.
2. Do nothing.
3. Move the axle down, SOA...
I can tell you now I don't want SOA.
What are your opinions on which would be harder or better set up?
I really don't want to cut the tunnel, but, I don't know if it is Ok to leave this as is.
Thanks,
It is not ok to leave it how it is.
You will need to modify the floor, do a body lift, or even both.
A SOA will only create more issues to address.
Good luck!
-Steve
