Anybody ever remove the catalytics on a 1fz-fe in the intrest of less restiction? If so what of the O2 sensor? Am I going to get flamed for asking a super noob question?
ok, Im working with a 97. 1: Does anyone anticipate a benifit from removing the cats? 2: If one were to do this what would you do with the down stream O2 so as not to mess with OBD2? Could you simply have the exaust pipe tapped and mount the O2 there?
Has anybody ran the dummy 02 sensor? Did they have any problems?
I guess my question is would you know it was a dummy if you were to scan the OBD?
Not sure. I know that the dummy simply provides a clean signal as if you have brand new cats working perfectly.
Did I mention it's illegal to install these?
ST
A rather simple and inexpensive mod, that I'm sure keeps the boys at the EPA in a chronic tachycardic state. Did I mention it's illegal to install these?
ST
It's only illegal if you get caught. I'm in the process of swapping my dual cats to a single cat so I can run the exhaust over the frame. This will cure any problem I have with that rear O2 sensor. Besides, the sensor is on top of the exhaust, inside the frame. I think that if on of the genius' at DEQ happen to find it, it will visually look correct. Let me know if this is an unreasonable thought process. TIA
