Cut-n-Turn - Rear Axle
Central City, PA
I'm running FJ62 axles under my SOA 40. At that time I did the cut and turn on the front axle. I just finished a rear disc brake conversion. It works well, but the calipers hang a bit too low due to rotating the axle up during the spring over. Is there a way to cut and turn the rear axle flange, or should I just fab my own? Any other suggestions?
Thanks!
Welded or bolted brake caliper brackets?
Either way, I'd modify the brackets instead of the axle.
