Cut-n-turn done...
Carthage, MO
I finished the cut and turn (14 degrees for pinion, 4 for caster) for my spring over, but I did not tack the spring perches in place before I pulled the axle for final welding. :doh: My question is-do I set the perches to 0 degrees or do I need to throw the axle under the rig again to take measurements? Thanks!
Ditto,
It really depends on your front spring setup, mine slope backward probably 5-10 deg which is significant
