So I finally threw my new driveshaft into my truck, the LR D2 with FZJ80 axles. I had a CV shaft and it vibed so bad I had a multiple CV shaft made, but it still vibes above 60mph
and my rear end is good up until 80mph, so this is no good. My problem is that my pinion is only pointed upwards at 10* and my t-case output is up at 5* too. So ive got two bad angles and only 23" to work with in drivshaft length ( a disco has a shorter front shaft than an 80). I also have a compound angle of 1". The 80 pinion is 1" more to the pass side compared to the rover t-case. So basically my front driveline hates itself.
I am going to have the axle cut and turned by a local fab shop, not the one who originally did my swap. I will have it cut and turned so I have 5* of positive castor, and a pinion pointed directly at the t-case (rather than far below it, like it is now). Has anyone cut and turned a FZJ80 axle, is it any different to cut and turn compared to an older toy axle?
Now here is the difficult part. I want to re-center the pinion, so I can eliminate my compound angle. Im not too sure how to go about this, so please give me some feedback on my ideas. The pinion needs to be moved over 1" towards the drivers side. I have two ideas on doing this. One easier, one harder. Tell me if one or both will work. With both swaps the radius arm and spring mounts will be moved over 1" to accomidate the new axle location with the centered pinion. Steering and panhard rods will be shortened accordingly. Those are the basics, they are easy, getting the wheels re-centered is where im unsure of what to do.
Recentering plan 1: after cutting and turning leave the axle housing stock as is. Place a 1" wheel spacer on just the pass side. This will leave my wheels centered under the truck, and make it track down the road straight. A bit ghetto, but if it works, im happy. My worry is this: will having a 1" spacer on just one side fxxx with my steering and braking bad? I know my car will turn farther to the right than the left while turning in a circle and that doesnt bother me. My concern is while at speed will it turn funny? Also will the braking forces be different due to the extra inch of space on the hub? im thinking it wont since the tires will be centered on the road.
Recenterign Plan 2 : when the axle is being cut and turned, modify the housing. While the swivels are cut, pull the entire swivel with its tube out of the axle, and then add a 1" tube spacer on it and then weld it back on. This would make the housing 1" wider, and centered. I'd then have a custom shaft made 1" longer to accomidate the extra 1" of housing. My only concern as to why this wouldnt work would be the length of the tube attached to the swivel would not be long enough to be structurally sound if welded back in with a 1" spacer in place. Is there enough length on that tube connected to the swivel to do this?
Any help would be great. If option 1 will work without braking and steering issues i'll go for that. If not, what do you think of option 2. Thanks.
I have gone broke :whoops:
