Hey all,
Just getting into a little project for my 1HD-FT; and I thought this crowd might be interested. I've designed the intercooler which will be in fabrication this week plus I've sourced components to install an intercooler between the turbo and the stock cross over intake pipe on the 1HD-FT w/ EGR. I'm aware most people just remove the EGR's but, I'm trying to within reason keep it as stock as possible. This is going to be a small W2A intercooler; I'm curious to see how much of a gain I will actually net. Main reason for this is when it's really hot out the performance decrease is noticeable & annoying. So if all this gains is consistency I'll be happy, but obviously I am hoping for a bit of a boost.
Main Components:
Custom Intercooler using a small core from bell intercoolers.
Bosch style electric water pump w/ 19mm lines.
Radiator from a Yamaha ATV with 700cc engine.
Plan:
Remove everything from in between the turbo and the intake crossover pipe including the intake preheater screen. I might source an inline dc coolant heater so that circuit still works as the ECU intends; still not decided on this. Then, I'm hoping my EURO spec truck has the wiring installed for the CDS fan and I can repurpose most of that wiring for powering the Electric water pump with an OEM look and style. This is yet to be confirmed as my truck is in the shop awaiting new injectors; 4 of 6 were heavily over fueling.
As for testing I'm not planning on doing much. There's a long steady hill on a 80kmh[50mph] hill that I'll go up in 4th and keep the speed & throttle the same for the hill and record air temp, boost, EGT temp and compare to afterwards.
See attached photos.
Main Components:
Plan:
