Custom front bumper mounts
Medford, Oregon
I'm considering making a front bumper out of 2x4 tube but I'm not sure on mounting. Has anybody made one from this material and if so how did you mount it. I searched and there are alot of threads on bumpers but none show the mounting. Pix are worth a 1000 words. Thanks
Hi All:
I made a custom front bumper (very simple, actually) out of 1/4 inch thick six inch "C" channel. Re-used the stock front bumper mounts - those triangular plates that connect the stock front bumper to the front frame rails.
Sorry, no pics available!
Regards,
Alan
Seattle
I took my front bumper and chopped it off on the ends turned them around and used them to close it in so its not as wide and a lot stronger. I would say if you have the tools that the best bet would be to cut 2 holes the size of the frame rails into the back of the 2x4 stock and insert the framerail into the holes and then drill a couple holes and use some stout bolts and then for extra strength you could always weld the spot where the framerail enters the 2x4. Heres a pic of my bumper even though its using the original mounts still it gives you a little idea of the framerail going into the bumper through the holes I left open.
my bumper is similar to what youre building yours as. I welded caps to the end of the frame, and bolt those to the bumper. My frame is also boxed in, so theres metal on the inside of the sides of the frame too.
Heres a pick:
attachment.php
attachment.php
-Dustin
I just finished mine not too long ago. I welded 3x4 angle to the 2x4 tube. The angle lays on the frame rails. Then drilled and welded slugs into the sides and top of the frame rails to bolt the bumper to. BTW - if you extend the angle past the front cross member, you will need to shape it a little for the bend in the frame rails.
One of the reasons I did this, is I wanted to weld the front hoop to the angle, so it could be unbolted with the rest of the bumper.
Well that's like a 1000 words. Maybe I'll try a pic later.
-Rick
I used 2x4 box with 1/4" walls. I capped the end about an inch past each frame tip. I took some 1.5" wide straps and put them in line with the top of the frames and drilled holes in them so the bolts for the tow hooks go through them. It doesn't have strength for pulling on, but that is what the tow hooks are for. It has taken a few hits from rocks with no damage. It also looks good.
I also used angle and laid it on the frame rails and welded it to the front bumper. I just finished my bumber and it is very strong. I then used two huge bolts to bolt it on each side and put some very small welds on it so it cant get stolen. I also have a stinger and nose guard on mine. I will get some pics this weekend. It was really easy to do and seemed like it would be the dtrongest. I also used 2x4. If you have any questions pm me.
