Custom Aluminum Rear 60 Bumper
NorCal
I just finished my custom rear swing away bumper before my last trip to the eastern Sierra and took a couple pics (more coming soon). Its all aluminum, titanium and stainless. It swings completely out of the way including dual bike rack, spare, and stainless :) jerry can.
(click on the pics for larger version)
I wanted to build something lighter weight than the steel ones on the market and I wanted to be able to use this style of bike rack and have it all swing out of the way and be hi and clear for 4 wheeling. It was mostly made by TIG welding water jet cut aluminum and a little custom turning.
The lower bumper is made of 1/4" wall 4x6" box tube cut away to wrap over the frame/standard bumper mounts. I added four 3/8" tabs to pick up some extra direct frame mount bolt holes. The wing plates on either end are 3/8" aluminum.
Embedded in the left (my drivers) side is a piece of 2.5" diameter aluminum rod that I turned a hole into for my hinge pin (1" 6-4 titanium). That piece is welded in and a 3/8"-16 stainless set screw grabs the pin in a hole I machined in it (the hinge is also captured by a stainless circlip on top of the bearings). The upper portion of the hinge is made from a piece of 3" aluminum that I turned with an oversized 1" hole and bearing seats for 1" ID tapered roller bearings (corrosion resistant). That piece was then welded to the 2x4" cross member (3/8" wall) with some extra bracing and a titanium top cap/brace is fastened to the top.
The hinged arm has an upright for the wheel mount, a through bolted 2" receiver mount for the bike rack, and the custom made jerry can holder. The jerry can is held in place by a stainless J bolt with a butterfly nut on the back side and security lock. The arm is held in the closed position with a stainless latching destaco clamp.
Under the 2" receiver for the bike rack is a chunk of braced 1/2" aluminum that takes some of the downward force of the bikes when the arm is closed. It is also drilled to allow a locking point that locks the cross arm closed and the cable to the bikes.
Afterthoughts:
- I want to add some beefy pickup points to the lower bumper for recovery and a hi lift jack.
- I still need to add a spring loaded pin to lock it in the out position.
- I should have pre-angled the swing arm so I don't have to lift it, for it to close all the way. I may still solve this with a ramp on the hinge now that I know the total sag when loaded.
looks good. how do you like your SC VPP?
I love the Blur LT. It climbs better than hardtail amazingly, and loves to come down fast rough trails that my hard tail would beat me up on. It doesnt corner as tightly though in slow technical switchbacks, but I think that is the trade off for a more relaxed head tube angle and 5.5" of front and rear travel.
I like. Very cool.:cheers:
:eek:Holy Bank account batman:eek:
I looked through the rest of your album. How much did you have in the engine swap?
It looks really well built! And expensive! :doh:
So, what was the total weight?
I was in a hurry to get out of town so I did not get a chance to weigh it all in. But I dont think it was more than 60lbs or so (Kaymar steel version is about 140 lbs I believe).
Cost was minimal as I had almost all the materials on hand except the hardware. I probably spent about $400 on hardware and waterjet cutting. The rest was sweat equity :)
You probably mean 6061-T6.
Super sweet bumper! I am impressed. Did you Tig it yourself? Where on the East Slope are you going? Have fun.
:cheers:
:cheers:
Yes thanks for catching my dyslexia :)
The trip was for labor day weekend, and I went to the East Side of the Sierra... Mammoth, Bishop, hot springs etc.
X2..........awesome can
These guys sell the 5 gallon stainless jerry (they incorrectly picture a 2.5 gallon). It is very well made and my favorite part is that it doesnt have one of those EPA spouts that spills fuel all over th place (about the worst example of government policy driven design yet).
http://www.central4wd.com/inventorydetail.aspx?page=id|31761
Very nice build, Zander. Well done.
:cheers:
