Cummins question
Tempe, Arizona
Hey, I've been doing a bit of reading on the 4BTA and 6BT conversions. Most people say you need a 4" lift or so to clear the cummins oilpan.
I was reading through this thread on Pirate...
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board
Isuzu diesel, 4BD.
I noticed on the third page he mentioned something about the Cummins main complaint being how tall it is and clearance issues and that the Isuzu motor offered quite a bit more clearance.
Just how much clearance are we talking about the Cummins requiring (I'm asking how much shorter it'd need to be to clear with a 2.5" lift, just 1.5" shorter, or am I missing something. I'm looking to see if swapping the Isuzu can be done with no huge lift)?
For the people curious about power;
The Cummins is a tall motor. Plain and simple. You're looking at least 2"-3" body lift to fit that beast in there.
That's why I'm asking if the 4" lift is required to clear just the oil pan. If that's the case then I'd imagine the Isuzu will fit with a standard OME lift.
4" lift minimum for the 4bt..Don't forget that with a few pump mods you can get way more power than an 80 series can handle out of that little Cummins..
well thats an oil pan I'd like to see.....
can it be clearanced, with some type of drain back?
is the crank set high? can you get away with a low pro pan and just change the oil more?
I say that b/c I believe part of a Diesel's large oil capacity is for longevity between oil changes...
intervals in a 4bt are what 7k miles?
I think the 3.3 is lower profile (destroked) and wonder what you could get out of it if it was slapped and tickled? (:grinpimp: I love my new analogy :cheers:)
Probably cheaper too....
I asked about clearancing the Cummins pan once but I don't think anyone ever replied. I'd love to see pictures of under the engine on a truck equipped with a non-Toyota diesel.
