Cruiser in Trouble "Low Compression"
Vancouver B,C Canada
Hey there fellow Cruiser Nuts. Looking for some advice.
My faithful 84 BJ60 has been given a diagnosis of low compression. I took it to Bill and Walters in Burnaby, as I was referred by a fellow Cruiser nut.
I basically couldn't get it running with the cold snap we are experiencing. Cleaned the battery terminals, added some c-taine thinking I may have some bad fuel. Drained the water separator. No go. My only luck was with a jump, but then my luck ran out.
After being towed, they confirmed the glow plugs were good. They checked the lap of the valves and they were in spec. I was told the only thing it could be was compression. They fitted a new block heater and sent me on my way. They said it wasnt worth getting compression readings, and that I'd need to plug it in.
I'm in shock still so any advice would be helpful.
Cheers
Why would not taking a compression reading not be helpful? It would tell you exactly which cylinder was at fault.
That makes me so mad. If I were you I'd march down to the autoparts store and purchase a diesel rated compression checker. Call a buddy to help you and promise him beer. Check the compression, and then you'll know which cylinder is bad.
Information is power when you are diagnosing a fault.
Yeah, a reading (ie data) is nothing but helpful. Get a gauge and DIY if you can. Better than data is data you can generate yourself and learn from. :beer:
If I am looking at a worn out 3b. What are the realistic options? Top end rebuild? Complete Rebuild, or will the data provide option for a more targeted approach?
Option C
Compression can tell you a large amount about the motor. A compression that slowly falls indicates leaky valves, especially one with a hiss sound. Overly high compression indicates carbon deposits. Generally low compression usually points to failed piston rings.
Why would they install a block heater before properly diagnosing the issue?!
X3 on the compression test.
Have you experienced a slowly decreasing amount of power? Or was this something that happened all of a sudden? How many miles are on it?
Georg @ Valley Hybrids
I know, right?
"Sorry there's something wrong with your motor. We're out of doughnuts so... here, have a block heater!"
560,000k. I have no real business complaining, this truck has been a reliable beast. No noticeable reduction in power, just a cold snap and she wouldnt start. I got it going with a jump a few times, until it plain wouldnt go.
Typically, I did have to warm the glow plugs a few times, and had a smokey start when in the minus zero conditions. Then it seems to run like a top.
If it was me, I'd go find a real diesel mechanic and get a cold and hot compression test done, as well as leakdown
if the compression showed something.
Or yeah, buy a compression tester! But a diesel's not quite as easy as a gasser to test...
t
For a hard-starting diesel that doesn't burn oil, and has no noticeable decrease in power, I'd suspect a worn injection pump or injectors before a compression problem.
A worn injection pump and bad injectors can make a diesel an absolute bear to start.
