Hey All, If you didn't see my earlier post, I just acquired a new to me cruiser! I figured I'd start another build thread to catalog this truck. I'm planning on building it up fairly similarly to my last truck and it will probably take a while. I'm going to be splitting my efforts between the cruiser and my M715. At the moment, I've started ordering all my parts to fix what's needed before going any further.
To be fixed:
Rear hatch handle and mechanism (rusty and the handle is gone)
Replace the broken tailgate hinge
Replace the washer fluid diverter valve
replace the broken wheel, powder coat all wheels
new tires (33" BFG KO2's)
remove rusted out factory hitch and replace it
repair trailer harness
full tune up (plugs, wires, cap, rotor, ignition, air filter, oil change, coolant chant, PHH replacement, re-grease birfs, change axle and Tcase gear oil)
remove running boards and mud flaps
clean slider windows and attempt to mitigate further corrosion
check the brakes
This should keep me plenty busy for a couple of weeks. I'm also thinking of bedlining the rockers again. Michigan has tons of rocks on the road so every bit of protection helps. There's also some rust bubbling up the front passenger door that the bedliner can hide and inhibit.
After all of this, she'll eventually get a 2.5" lift, extended brake hoses, ARB bumper, Warn VR10,000 winch, 4x4labs rear bumper, snorkel, center lock switch, sliders, roof rack, CB, Aux lights, etc. I'm aiming to have it look kind of like this one:
Here's how my last truck looked:
Hopefully I've learned from my past mistake and I don't get rid of this one. I'm excited to get cracking on this thing!
To be fixed:
check the brakes
