Cruise control issues on a 93
Oakland TN
I used my cruise control for the past few days without issues. Tonight on the way home it stopped working. The cruise light came on and when I went to set the speed it flashed and then went off. After that it wouldn't come back on at all. Anyone else have this issue and know of the fix? I'm going to investigate further this weekend.
Thanks
Wow, it could be one of many things causing your cruise control problem. I have a 93 as well and I'm looking at the 94 FSM. There's an entire section on cruise control diagnosis and trouble shooting. \
I would say get the FSM for your truck and try and check it out on your own . BTW , get the 94 FSM. It's much more detailed than the 93. the 93 and 94 model year cruisers were pretty much identical with the exception of the AC dryer and 134a.
:cheers:
BTW- the cruise control system has it's own diagnostic trouble codes, #11,12,13,21,23,32,34,41 the Factory service manual
explains all of these in detail
Mine did this sporadically (turning the engine off fixed it momentarily) Then I read a thread here instructing spraying WD40 on the actuator linkage (at the cruise servo) and it has not happened again, that was over a year ago.
Thanks
I had a similar problem, and it turned out to be moisture in the sending unit for the VSS (plugs into driver's side of the transfer case). The rubber boot on those can get loose and the moisture gets in. Remove, clean, blast with WD40, and replace.
Are your gauges all working okay? Your cruise is tied into the VSS, and if your tachometer is pulsing, that means the VSS is not working properly. If your tach is acting up, the cruise won't work.
my '94 did this on my way home from the Easter Sierras today. Anyone have a definitive fix for this. Mine did exactly what mcfj40 described. Pushed the button, cruise light came on for one second and went out and wouldn't come on again.
My '93 does the exact same thing whenever driving in rain. I'll try cleaning and WD40 at the servo and at the transfer case plug. I'll follow up the next time I drive in the rain.
Hmmmm......
OK maybe different but here is what mine does.
Engine off, fire up, take off down the freeway, engage, set no problem. Cruising.
With it set I can easily disengage, cruise light stays on, go to re-engage..... nada.
I will have to pull over and turn off for 15 or so..... hit the highway again, lucky if it will turn back on...... but heres the strange part, any given time down the road it will work again.....
My thoughts are new combo switch/relay in the steering column and or button switch on the control arm (for setting, accel, ressum).
Leaning towards the combo switch from what i've read... esp. since my intermediate wipers don't work and blades dont sit to their "down" position. I believe them to be the same switch.
DO THE FSM DIAGNOSTICS!!!
There is NO reason to guess at what is causing a cruise control failure; it's all in the book. You can test every single circuit/component right from the driver's seat.
Curtis
Mine light comes on, cruise control does nothing:confused:
On my 93, I could turn the cruise control on, but when I tried to 'set' the system, the cruise would light would blink three times and then go out. I could not turn the cruise control back on (identified by the dash light coming on) until the ignition key was cycled to the off position.
The fix I found after searching Mud was to pop the cover off the passenger side fender under the hood, and cycle the actuator cam on the electric motor through it's full range of motion a few times. I did this, and my cruise control has been working ever since.
