Crossposting for help with light wiring
Pennsyltucky
I started a thread over in Camping but wanted to cross post here because there's more traffic. And you guys are smart, too.
LINK
I need advice/help with making a temporary wire harness to run some amber roof lights on the back corners of an extended body Ford van.
If you can help me out, I'd appreciate it!
Thanks!
I guess depends how much of a hack job do you want to do. If you want to keep it simple, I would get a fused accessory splitter, cut the wire and extend it to the back. If it is not fused add an in-line fuse. You could use the plug itself as a switch, or add a switch in the wire. Good luck.
Thanks for the response--I'm kinda worried about the number of cig lighters in the van, stock, and was thinking of running this temporary harness straight from the battery to the back of the van, with the switch near the driver, to save the stock power outlets for other gadgets (GPS, iPod, cell phones, etc.).
