Crossmember drop spacers
Hailey idaho
Has anyone ever done this to fix a front drive shaft vibration? Is it even possible? I know Jeep guys do it. I have 3" lift ome j springs. Just did the slee castor correction plates and they worked great but now I have the vibration. Any ideas would be helpful. Thx
Just do it the right way and get a double cardan driveshaft. You can use a Tacoma rear shaft or something to splice with one of the ends. Do a search and you'll find how to do it. Cost me like $150 for a used driveshaft and the driveline shop to do their magic.
Before you drop the cash on a DC shaft how old are your u-joints? You may be able to just replace them and fix your problem.
Add some grease to your current u-joints and see it that quiets it down.
I've only had this rig for a month or so. Not sure how old the u joints are. They feel tight though. Didn't have any vibration before the castor correction plates. Got 215xxx miles on it. Christo Slee said this would happen with the kit. I am just curious if dropping the tranny an inch would relieve the pinion angle.
Could you point me in the right direction? I have searched and can't find anything useful. I'm sure there are plenty of threads I just have a hard time sifting through it all. Maybe I'm not wording my search right?
I ran J springs on my last rig but only had a vibe once I added a spacer to the front end to level it out. Though I fully trust Christo's advice, if your u-joint are original (which they probably are) changing the angle after 215k they won't be happy.
You're essentially at a crossroad running J springs without any armor. You can add accessories like a bumper and winch which will lower the front or you can run a DC drive shaft, both with calm the vibes.
Solid advice. Hadn't thought about the fact that the ujoints are worn in at that angle. I'll check them first. I plan on adding bumpers and a winch this winter. Might do the trick. Thx!
I'm running a DC front shaft AND a 1" transfer case spacer. Understand the driveline angles completely before making changes.
