Crazy tranny conversion question: auto v. 3 or 4spd
Harrisburg, NC
Hello again..wondering if anyone out there has converted their 3 on the tree, 3spd or 4spd floor transmission into an automatic transmission...currently I have a 3 on the tree and will attempt a swap to a 3/4 spd transmission or automatic....is the switch to automatic crazy??....thanks...R
...complicated yes...can it be done??...hopefully....
with enough time and/or $$ anything can be done. I think the most common problem with the auto's is having enough wheelbase for a rear drive shaft. The front driveshaft may come close to the pan as well depending on what tranny you use. Most of the time it is with a SBC conversion.
Ditto, I've never seen one with the stock 6 cylinder. People do it all the time when converting to a V8.
We built, and I owned a 6 cyl. with 700R4 auto tranny. Would not have fit an FJ40 at all. Several unsolvable problems an FJ owner would have had, so we never put onto the market.
How about an FJ55?
I had the 700R4 in my FJ45, consequently I actually did have a rear drive shaft--- so would an FJ60. The problems where:
(a) chewed up 6 starters in a row for no reason whatsoever, no explaniation. All machining was 1,000% to GM spec?????
(b) My FJ45 6 cyl. had throttle body injection so the 700R4 kick down cable had something to actuate it. A stock Landcruiser carb is not set up to actuate the kick down cable, nor did we develope anything to take care of this.
well...thanks for the input...a 3/4spd floor shirter is looking like a better idea...:)
Jim
This is something I am curious about. How does a 6 cyl do running a 700R4?
Mileage? I grew up with the idea that auto trannys hurt fuel mileage. But technology has come a long ways since the 50s and 60s.
Torque? Will losing the heavy flywheel to put on the flexplate and torque convertor cause any loss of low end torque?
I am thinking specifically of the GM 292 since they will bolt directly to a 700R4. Possibly bored out with slightly higher compression pistons, a different cam to enhance low end torque, etc.
Any recommendations besides a long wheelbase?
