Crazy RPMs. Why???
Rolling Meadows, IL 60008
Hi. I am worried a strange RPM fluctuations while stopped at red lights. I own 1993 FZJ80 and while I stop at red light RPMs will go down to 350 - 400 then after 30 secs go up to 700-800 and then down and up all over again. I checked for air leaks and did not find any obvious ones. What else should I check for? Thank you very much for your help.
Is the engine RPM actually changing or just the gauge?
I had that once, and it turned out that my air intake was just jammed with mud/dirt from driving through a river.
This may be a stupid question to ask you, but is your a/c on when this is happening? If so, it's most likely due to the automatic throttle solenoid activating when your compressor cycles on and off.........
My 92 does this occasionally. I'm thinking it's about 650 rpm to 1000 rpm's. It just jumps up and down about 3 times then idles normal. AC is off and it's not the tach.
These are all very good suggestions. However I checked for loose or dirty hoses, air leaks, tach is fine, AC off. I thought maybe there is a sensor but I checked in the book and fuel intake is regulated through adjusting air. I will have to keep looking for clues then. Thank you for your help and let me know if you fond out anything else.
