hisandhers80s
- Thread starter
- #21
No since I have not been able to get it to run more than 3 minutes at a time
How do you know it's not blocked open? I'd actually remove the air intake hose and inspect, but ok.I tested that by having all of the cables (Throttle, Cruise, & Kickdown) unhooked from the throttle body. I do not know what would be opening the plate if there are no cables connected and it still happens.
I have had the hose on and off quite a bit, changing the AFM/VAF 3-4 times, as well as had the throttle body off twice to adjust the TPS, and it has always had the flap closed.How do you know it's not blocked open? I'd actually remove the air intake hose and inspect, but ok.![]()
I guessing you have a major vacuum leak after warmup.
AND I am happy to report that unplugging the Coolant Temp Sensor let the truck idle at 1,000 for 30 minutes just now!
That is my guess or I have the wires reversed in the plug connector on the harness. I am picking up another brand new OEM coolant temp sensor this morning and will find out. I am not certain if it matters which pin goes into which side of the connector or not so might test that first before changing the sensor.Faulty sensor?
Fingers crossed fer ya!I was able to confirm using a spare engine harness I have that I have the wires in the plug reversed. I am not sure if that matters or not, but I am going to try switching the wires in the connector and plugging it back in to determine if that is the issue or if it is a bad sensor. I also have a new OEM sensor I was able to get from the dealer this morning.
I did not swap the wires in the connector yet, so I may try that
if you had the scanner you could take a glance at it and it would tell you what the ecu is seeing for coolant temp, intake temp, etc. can unplug the ECU and measure the pins there for resistance, then after that load test each wire with an incandescent bulb, next check for short to ground and power.I would absolutely be interested in the TOYOBD1 scanner. I installed a new booster and master while the engine was out.
