Hi All,
As many of you know I'm clearing out the garage (and the other garage, and the other other garage, and the basement...)... EVERYTHING MUST GO!
I'm posting my stuff here first to give the local guys a crack at it, and because I still need to determine prices before I can post to the real classifieds here on MUD or to ebay...
I will keep updating this post as items are sold, or as I set prices.
Make me offers in the meantime at pghfj40@yahoo.com
Pix of all items are at this link: "http://s51.photobucket.com/albums/f396/pghfj40/Stuff%20For%20Sale/FJ40/" ...I will eventually try to link the right pix to each item, but that takes time. Here's the list for now...
Items are located in Pittsburgh, PA.
LAND CRUISER STUFF:
Other Land Cruiser-specific items:
OTHER OFFROAD-RELATED ITEMS:
Car Stuff, Other Makes:
Once again, pix of all items are at this link
Items are located in Pittsburgh, PA. You can call 412-337-7468 from 9am to 9pm EST.
Thanks for looking. -Ed
LAND CRUISER STUFF:
SOLD! '78 FJ40 wiring harness, COMPLETE, not hacked. [STRIKE] $250. Headlight switch is available separately - $40 [/STRIKE]
SOLD! '78 FJ40 horns (2), pic1 pic2 - [STRIKE] $10 [/STRIKE]
SOLD! '78 FJ40 Heater Box Complete with ALL original ductwork, see pix! (NO HEATER CORE included) [STRIKE] $40 -Nick [/STRIKE]- '78 FJ40 Warm Pull Cable and Knob $10
- '78 FJ40 Ventilation Blower, pic1 pic2 pic3 - $15 (one mounting ear is cracked, see pic2: repairable, or maybe you just want the motor/resistor?)
SOLD! '78 FJ40 alternator & Voltage Regulator, pic - [STRIKE]$25[/STRIKE] - '78 FJ40 Emergency Brake Handle and Cable $25
- '78 FJ40 steering column clamp/bracket and bushing good shape $10
- '78 FJ40 Steering Box (~45k mi) $80
- '78 FJ40 steering column/wheel/keyed switch (already modified for conversion joint, including lower delrin bushing) $80 joint is available separately, below $50
- '78 FJ40 Clutch Master AND Slave cylinder, w/ both hard and soft lines (all still connected) $40
SOLD! '78 FJ40 4 speed transmission tranny, low mileage ~45k. [STRIKE]$250 [/STRIKE]
SOLD! '78 FJ40 "4 speed" transfer case xfer, low mileage ~45k. [STRIKE]$150[/STRIKE]- '78 FJ40 Transfer Case Linkage & Shifter Knob (included w/ tcase if purchasing tranny/xfer combo, also may be available separately)
- '78 FJ40 4-spd 4 speed bellhousing (& clutch, if wanted) $15
- '78 FJ40 carb, vacuum computer, throttle linkage bracket, insulator & heat shield $100
- '78 FJ40 Auxiliary Carb Blower carb cooling fan assembly $25
- '78 FJ40 smog pump $25
- '78 FJ40 windshield wiper motor $25
SOLD! '78 FJ40 Brake Booster, master cylinder, proportioning valve [STRIKE] $50[/STRIKE] - '78 FJ40 Clutch and Brake Pedal Assembly (good condition) $25
- '78 FJ40 Hard doors, rusty bottoms, door stops, hinges and latches (may be available separately) $40/BO (local pickup only)
- '78 FJ40 Hard top Sides, rusty bottoms, good glass, one wing/vent glass missing. $20/BO (local pickup only)
- '78 FJ40 Rear Ambulance doors, rusty bottoms $40/BO (local pickup only)
- '78 FJ40 Hood, some rust (local pickup only) $40/BO
- '78 FJ40 Windshield, rusty, good glass (local pickup only) $20/BO
SOLD! '78 FJ40 bottle jack, handle [STRIKE]$20[/STRIKE]
SOLD! '78 FJ40 Rear Step [STRIKE]$40[/STRIKE]
SOLD! '78 FJ40 Sun visors (qty 2) [STRIKE]$50 shipped[/STRIKE] - '78 FJ40 Rear Tub Mat $40
SOLD! '78 FJ40 Rubber Floor Mat, Covers entire front, embossed "Toyota" ...NICE! [STRIKE] $120 [/STRIKE] - '78 FJ40 Battery Tray $15
- '78 FJ40 tail light lenses (average condition) $15
- '78 FJ40 glove box door, good original condition $15
- '78 FJ40 lower dash pads, very good shape & pliable (long one has negligible crack on bottom) $20
- '78 FJ40 OEM Steel Wheel (only ONE) with hubcap clips, retro lookin' Dunlop H78 FJ40 M&S Tire good tread mounted $40/BO (local pickup only)
SOLD! '70 FJ40 driveshafts, excellent shape (no dings, rust) [STRIKE] $65 [/STRIKE]- '70 FJ40 alternator, pic - $20
- '70 FJ40 Fan Shroud (No Rust) -$20
- '70 FJ40 Transmission Inspection Cover Plate $10
- '70 FJ40 Vacuum Computer (condition unknown) $10
- '70 FJ40 Instrument Gauge Cluster (condition unknown--I think 1/10ths didn't turn) $10
- '70 FJ40 Rear Heater Assembly (heater core seems good, fan motor not included) $25
- '70 FJ40 Choke Knob and Cable $5
- '70 FJ40 speedometer cable, turns smooth but housing does have one crack $5
- '70 FJ40 gas cap $5
- '70 FJ40 hard top sides, decent, rust on bottoms, local pickup only - $40/offer
- '70 FJ40 OEM Steel Wheel (only ONE) with hubcap clips and hubcap, worn but retro lookin' M&S Tire mounted $40/BO (local pickup only)
- '70 FJ40 Hard top Sides, rusty bottoms, good glass. $20/BO (local pickup only)
- knuckle trunion bearings, SKF Germany 30303, from JTO, good, condition used only ~1-200 miles (qty 3 avail), plus knuckle trunion bearing preload shims, large bolt pattern, assortment, new $20
- 'Ramsey PTO Power Take-off unit for Land Cruiser FJ40 3-spd transfer, mfg 1972, includes dash-mount knob/cable, shipwt=20# - $50
- (3) coarse spline birfields $30
SOLD! Warn hub rebuild kit [STRIKE]$10[/STRIKE] - 2 sets of Land Cruiser FJ40 spider & side gears w/ bushings, center pin, bolt; 1 set adjuster nuts & low mi carrier bearings, center block (for semi float/c-clip differential) $10
- Muffler $5 (free locally)
- (3) FJ40 Mechanical Fuel Pumps (multiple years/styles, see pix) $15
- Brake flex hose, 10x1.0mm, (can be used as extensions), (qty 2) @ 22 inch and (qty 2) @ 7 inch $10
- (4) Fender flares, used, not perfect but very serviceable $25
- custom steering stabilizer to tie rod mount $10
- Borgeson PowerSteering conversion U-joint, Land Cruiser column to double-D shaft, NEW (installed for mock-up only, never driven), $50; Saginaw power steering high pressure hose (included free with steering joint);
- '78 FJ40 steering column/wheel/keyed switch (already modified for conversion joint, including lower delrin bushing) is available separately $80
SOLD! Spare Tire Cover, grey: "Land Cruiser: Drive a Legend" [STRIKE]$25/shipped[/STRIKE]
- PowerTank PT-10 Candy Blue, Brand NEW! $325 includes:
o SuperFlow HPx Regulator
o Aluminum Luxfer CO2 Tank with Sherwood Nickel Valve
o Tank Boot
o Regulator Cover
o Power Grip Guard
o Super Bracket
o SuperFlex 25' Hose
o Air Lock Coupler
o Ball Air Chuck
- 2 Gallon Air Tank for OBA System (Blue) $20
- Tuffy Overhead Security Console 048, Shipping Weight 22# $200
SOLD! Winch roller fairlead, good condition, used 1-2x [STRIKE] $20[STRIKE] - SM420 transmission Muncie Granny Gear 4-speed tranny 7.1:1 first gear, 10-spline in and out (condition unknown, good at least for parts) $60
- 1992 Nissan 300ZX Factory Service Manual FSM [STRIKE] $15[/STRIKE]
- 4 Aluminum 5 spoke rims with new 225 and 245 Kumhos, Borbet Type T, includes lugnuts with locks, extra center caps, 5x100mm bolt pattern, tires & wheels like-new (under 100mi) $250
- one used all season car tire P245/65-17 Goodyear Wrangler SR-A $20
- two used truck tires Apache All-Terrain AT 265/75-16 $25/ea
- 1999 Chevy Silverado fender, right front, Pewter $50
- turn signal lens/housing (2), 1999 Chevy Silverado $15
- headlight lens/housing, right, 1999 Chevy Silverado $15
- 1999 Chevy Silverado 6.0 air intake box $15
SOLD! - Ford F150, F250, 98+ Pickup Truck, Luverne tubular Side Steps, new/never installed, with hardware [STRIKE] $110 incl shipping [/STRIKE]
