I've got a '97 LX450 with 273K miles on it that just developed it's first leak and first real mechanical issue. First- the front crank seal went bad but before I got a chance to get in there and replace it, I started having a problem with the engine just cutting out when I make a harder right turn (only right that I know of). From some research I *think* it's the crankshaft position sensor. So this weekend I dug in and replaced the front crank seal and got under the car to get to the position sensor. I've got the FSM so was following some resistance diagnostic checks and one is throwing me off.
Checking the distributor resistance is good- within range, haven't checked for a short between the ECM and the position sensor yet, and can't imagine there's an issue with the ECM itself since there's no other problems.
Then I go to the next circuit for checking ("B") and the resistance between the terminals for the position sensor connector is way off- 93 k-ohms. I went ahead and checked the resistance of the sensor and it was all good.
Mt question then is why would the sensor need to be replaced is the resistance on the connector is bad? I'm no mechanic so I just don't understand the logic here- any help? And does anyone think that replacing the sensor will actually help or have any other ideas as to what might be an issue?
Thanks!
Thanks!
