Today I was driving my 94 Land Cruiser to run a errand. It was running good (no changes/maint has been done recently either) then when I came to a stop the idle droped down to 400ish rpm then died. Now when you turn the key it spins but will not crank.
So far I have done:
- Check battery and cables (battery reads 12.6v)
- Motor spins and cranks but nothing happens like it trying to start
- Tank has 3/4 gas
- No spark when I pulled plug 1 (did smell the plug and smells of gas strong)
- Swapped efi relay with a new Napa replacement
- Checked EFI 15 amp fuse in fusebox (did continuity test to be safe)
- Checked AM1 fuse in fusebox (did continuity test to be safe)
- Have 12v at the bolt head in the fusebox when key turned to ON
- CEL is on when the key is turned to on
- The red light on the dash above the voltmeter is on when i turn to ON (first time I have seen this, could be nothing)
- On Pin 3 of the EFI relay I get 11v
- On B+ of the diagnostic port I get 11v
- I thought I did hear the fuel pump running when the key was on the ON position
- My dome light & wipers work (that confirms fusable links right?)
Update
- Tested the coil resistance and its at .5
- Ordered new fusible link, will pick it up and install tomorrow
So far I have done:
- Tank has 3/4 gas
Update
