Crank Pulley Cover
Santa Fe, New Mexico
Nothing major, just a half-wasted piece of sheet metal on my '75 with a 2F. The spots where fasteners hold the sheet metal to the frame are cracked, or completely broken. So I did a bit of fab with a 1" strap on the side where the cracks are propagating to give it a 'spine.' I used 1/8" pop rivets.
(Technically, I might have a Chevota, because a previous owner installed a metal fan similar to what you might find on a GM 250 straight-6 to the water pump of the 2F.)
On the other side, I simply harvested some .050 sheet metal, with a half-hole already in it, from the heat riser gasket on the exhaust manifold to shim the other side of the screw that goes into the frame, that is that tab sticking up from the rusty screw, next to the new one holding the battery tray. I also added a washer between the sheet metal, back, and the frame because the whole assembly is a bit narrow for the frame and stretching it could have initially contributed to its breakage.
By the way, after drilling the 1/8" rivet holes, I used a Noga hand-countersink tool, which works awesome for light-duty fabrication projects from pine or fir to mild steel, for cleaning-up burrs and blow-out. It isn't as good as a countersink in an electric drill, but it is far more convenient.
