Crank case breather needs modification?
Costa Rica
Website
www.orodesigns.com
I have a problem with this 65 F motor breather.
When I work the motor hard on the hwy it pukes out oil all over the front diff and right to the back.
Anyone have a suggestion on how to modify this breather tube.
I have been thinking about a baffel in the filler tube?????
Cut the damb tube and route it to a can with some hose?????
It is a mess after a day on the hwy. If I don't clean it up asap. the dirt off the local roads sticks like s*** 2 a wool blanket.
The only good thing is the tub and floor boards will never rust when it is coated in oil. That is prob. the only thing that has saved this 65 from rusting after 40 years in the salt air here.
Any help appreciated
send any info to
steve@orodesigns.com
Sounds liek you have a lot of "blowby" from worn rings. I take it the engine is too old to have a PCV valve?
Ed
Ed
F engine: What the hell is a PCV valve? :D I like your hose to a baffle can idea.
Maybe route the fumes up through some of that tubing until it blows out the back at the top.
BTW - Are you maybe building a double-decker bus?
Thanks guys I will try the hose and filter deal.
Note to honk: The double decker works great when ya have to load up your gear and hit the beach.
I guess with a the rigs you have ya never have to pack plywood in your cruiser.
i have a 63' motor in my cruiser and it has slits for vents on top of the valve cover, i got a later valve cover that has a pvp hose on it i think a 67' from mark at marksoffroad.net. I still need to find the oil fill tube that dose not hava road overflow thing on it. A little history for you all, my F motor says 115 F on the side. Is this some older 135f motor.
