crank angle sensor on 2F
Wellington, NZ
Has anyone fitted one?
Am looking to go distributorless igniton. Is the easiest way to just mod my HEI and leave only one 'trigger' on the rotor, or to fit something to the flywheel or elsewhere?
All suggestions welcome :)
The Ford EDIS with a 36 - 1 toothed gear attached to the crankshaft pulley is also an option, but you would then need to build a distributor shaft plug to drive the oilpump. I am bouncing back and forth between which is easier to do, the 3fe dist, or the Ford EDIS. I am leaning towards the 3fe dist at this point as Matt has already done it.
I've looked at the edis - not sure how it would handle the mud. But it's the only option to drive a megajolt...
Trying to find if anyone has developed an adaptor between a nippon-denso and a megajolt.
