Cracking/click noise in engine bay
Utah
I have been searching about a clicking/crack type sound that is coming from my engine block are when I turn the vehicle off. I also sometimes notice it just after starting the engine as it warms up if I have the hood open.
I noticed this sound pre-S/C install, but today I took it on a short (10 min) but somewhat heavy skinny pedal trip. One mile on 40mph road, got the rpm to just over 3K with the water temp around 140. Drove on a freeway (about a mile) with heavy excelleration, water temp ~170. Then light driving one mile back home, mostly down hill. When I got home I opened the hood. The blower was only slightly warm and the intake tube was almost cool to the touch. My water temp didn't get above 182* per Scangauge. However, I heard one cracking sound sounded a little louder than usual. It doesn't sound like the usual exhaust "tingy" type sound when cooling off. I am pretty sure the sound is coming from somewhere in the block.
This was all I could find.
https://forum.ih8mud.com/80-series-tech/138655-load-cracking-popping-sound.html
https://forum.ih8mud.com/80-series-tech/26958-single-cracking-noise.html
I am having similar sounds to those listed in the above threads, but I haven't been able to find any solid possible answers.
Does anyone dare to take a swag (scientific wild @$$ guess) at it?
Thanks in advance!
My bet is that it's exhaust related, the heating up and cooling down.
You're screwed. I'll do you a favor and haul your rig away without even charging you.
sweet, that's a load off my mind. I'll bet the:princess:will make you a gourmet dinner and give you 100$ for your troubles too.
I have heard the sounds coming from the exhaust area, but this sound is different. I haven't noticed any poor performance or red flags, but I'd like to know if anyone else has had this type of sound and if it has caused any problems.
Its hard to tell what's what over the net but almost all vehicles have some "settling sounds" after shutdown coming from the various thing that got hot under hood then getting cool. I have noticed a cacophony of sounds after shutdown. The exhaust tubing itself tends to make a rather rapid and tingy sound that repeats slower and slower as the engine cools. The thick heat shielding that I have makes much slower and much louder sounds almost like it is "settling" in four or five larger moves as the engine cools and those four or five moves happen in a relatively short time after shutdown. The catalytic converter is a softer sound but so rapid it sounds like John Bonham on a single small cymbal and it goes really fast for a really short time then it stops alltogether.
You may have heard something large settle or you may have heard a crack as in a problem but it is hard to tell what's what this way. Just be assured that almost all vehicles have some settling sounds after shutdown. HTH. :cheers:
Thanks guys,
I guess there really isn't anything I can do, but keep an eye on it in case it becomes more noticeable. The head gasket should be good as it was replaced by the PO at a dealership about 40K ago. The cooling system appears to be in good shape as well. I'll report back if I notice anything strange. :beer::popcorn:
