cracked rock warriors (replacements?)
Last November I found what looked like a decent set of RWs, bought some KO2s and had them mounted. I've been driving them everyday on the highway since then, no off road (sadly), for about 10k miles, maybe less. My right rear started going low, and I checked for nails/screws (common reason for flats around here) and couldn't find any. Sprayed soapy water everywhere, and couldn't find a leak. Pumped it up, and it held for 2 days, and then went flat again. Pumped it up and drove it (repeating this cycle) knowing it would get worse and help me find the leak. Eventually found two cracks on the inside edge, straight in from the edge. I have no idea how these cracks would have happened - there's no damage around them, I didn't hit anything hard, but I don't know how these things fail, so maybe this is common? It just seems like a weird way to fail. It's also forcing me to get a better air compressor since sitting in the parking lot at work for 20 minutes waiting for it to fill up was painful.....
Questions - is this common? I like the RWs for many reasons that others do, and figured they'd be more reliable than this. A quick search here and google and I don't find much in terms of problems with them like this. Can this (*should* this) be repaired, or just toss it and get another one? My wife is suddenly not a fan of these wheels and thinks I should get new ones. Any suggestions on new wheels that would be similar to the RWs in terms of quality (except for mine), durability, size, fit, etc.?
Thanks.
Not typical at all.
I have personally inspected close to 40 of them as I have found, bought, and passed-on-to-other-mud-members **9** full sets of used Rock Warriors over the last several years—plus a few spares...including my own set of 5 that I seriously abuse.
-In all those used RWs...I have never seen a cracked one. Very strange.
Can you post a photo of the crack?
(EDIT: I see a photo was posted. Missed that!)
Wondering if a bad batch of metal snuck into production with that wheel. Crazy...
Scroll back a bit
Doh!
Wow. That’s nuts.
Seems like that wouldn’t be a SLOW leak!
But I guess it’s mainly pressed up against the bead...
