Cracked head
xxxxxxxx
xxxxx
cracked piston
Dont know your situtation but to drop a valve to me = high milage / worn out motor to install one piston is a short term fix, did the rod bend , are other valves streched and soon break? You didnt state mileage , 79 blocks are getting rare {i got one on my 78 so i could run factory ps and 78 head} sounds like you got luckey and didnt trash the block, i think 75 head will work ok on 79 2f . Its my understanding that an 80 and up flat piston block has smaller combustion chamber and different water passages that is why you cant run dome pistons and a 78 head on an 80 and up block hope this helps mark :cheers:
If you decide to go cheap and want to replace one piston, I have one, well actually 6, but maybe no rings, have to look. I was not worried about salvaging them at the time.
Sounds like you need a bore gauge, and some plastigage.
How do you spell G-A-U-G-E? I have NFI, obviously.
Ed
Aaron, I wouldn't replace just one piston/valve. I would put the '75 engine on the stand and Plastigage the bearings to see how they are. If the bottom bearings check out OK button it back up and drop it in. It's faster, cheaper and easier to swap an engine than to rebuild one. If the '75 is running why cannabalize it?
