Crack in block
splitshot
Head cook, Bottle washer, and Peace keeper.
Rodent Central, Az
got a hairline crack above and below rear side freeze plug. Had to use expandable plug as factory plug won't hold.
Any good sealant out there so I can get some more life out of this f
engine?
JB Weld will hold it for a while. If you lightly grind the cracked area and mix a good mix of JB Weld I've seen it hold as long as a year. Eventually depending on how much you drive it that crack will increase. When that happens you'll start loosing alot of fluid and have to call it a day and get another block. Keep a good working temp gauge to monitor so you don't destroy all the internals. Good luck with it.
PM IDave, he has done this with some success. Not in the same place, but a larger, longer crack.
GL
Ed
I've tried a lot of things, JBWeld, Muggyweld, various radiator StopLeaks, and treatment with water glass. Things are down to a trickle, but it still leaks. If I were to try again, I would pull the engine and have a groove made into the crack and have it brazed while on it's side.
But I'm just gonna drop in a good engine from a good friend in MO instead.
That said, I've dded this for 2 1/2 years....
I recently built a new F engine because of this. My old F had a 1 inch crack on the driver side forward above the engine mount. It only leaked when cold. Over about two years and many attempts to seal it, it continued to grow to about 6 inches long. I decided if the only way to fix it right was to pull the engine, then I would just build a new one. I bought a 70's model F block from SOR. It was new, with cam bearings installed and new pistons/rings to boot. They still have some (PN 801-040-055 or 801-040-056). If you go this route be ready to spend more money. I thought I would just swap my old engine parts to the new block. Once I opened up the old F I found scored rod and main bearings, a thrust too far gone to be machined, scored cam journal, missing bolts, etc. Of course now I have a new engine that should last over 30 years with the right care.
Leon...
just curious but couldnt this be welded?....by somone who knows what their doing
Certainly it can be welded. The key phrase in your question is "by someone who knows what they are doing." Cast iron is a fickle metal that requires preheating and slow cooling and even peening depending on the procedure you use. And even when "done right" it can still crack elsewhere. That is why when I factored the cost in money and time to do it right with the gamble that it still might not work, I decided the build a new one.
A final thought. It cracked for a reason. You may fix that crack, but did you fix the reason and did that reason cause potential other cracks elsewhere on the block? This may sound doom and gloom and others will chime in with how many years their welds have held. Great. I hope it continues to do so. For me, my money and time, and my desire to have an engine to last the rest of my life I chose to build new.
Leon...
cracked block
had a fj55 f motor with a crack. Wire brushed it bigtime and had it "epoxied"...don't know the material used but it worked and held for the next 3 years that i owned it. welding is a big gamble as you may just push the crack longer as you weld. On other cast iron parts i weld witha nickel rod and drill a hole at end of crack to stop the run. wouln't weld on an engine block though.
