Cowl Vent & Window Frame Seal
Hi all,
I have been tracking down water leakage into the cab of my 67"FJ40 and there are three areas that I am focussing on:
> Cowl Vent - looks like all the innards of mine have been removed and the drain holes have been sealed with silicon. Planning on just resealing around the plate, but should I also cover the opening above wires? If so, has anyone found something that worked well?
> Cowl Seam - the cowl seam below the window looks like it needs to help -- can water run down the opening and enter the cab of the truck?
> Window Frame Gasket/seal - I think this may need to be adjusted or replaced. Will search and see if they are sill available -- but if you know of a vendor that would be helpful.
Thanks for any insights?
