could this be an alternator problem? 3FE
Santa Cruz
I would like to get pointed in the right direction. My 92 started doing something funny and I think it may be linked to the alternator.
Got back from a road trip over the 4th of July weekend on the way back I was running the A/C when suddenly my RPM's started undulating badly between 700-1200 till I turned off the A/C. I made it home then later tryed to start the cruiser= dead battery.
So I jump started it and it continued to undulate this time not as bad.
On a hunch I thought I may be having an electrical problem so I tryed to turn on my headlights then the high beams and WHAM it revved up and died. I had to jump start it again, this time shifting from park to reverse I had the same symtom as the high beams however it did not die and I managed to get it to its parking spot and so it sits.
I havent realy had time to check it out yet, but I was hoping someone could point me in the right direction or show me a link to the problem.
Thanks, Dave.
Here is a little picture for your enjoyment.
(Search keywords) 3FE 91 92 fj80 rough idle
I wouldn't jump directly to the alternator, though you definitely have an electrical problem.
Have you done anything electrical lately? any service? work under the hood?
FYI, the A/C will bump up the RPMs automatically every 30 seconds or so.
No, the only work I have done to it lately is the lift. I went to the repair manual and didnt find any leads there. I tried to search this and didnt find anything there either. And my A/C has worked fine before, this is definitely more than the norm.
On a side note, I noticed you have a duel battery setup, I am interested in the same setup. Where and how did you set up your second battery.
Have you started with using a multimeter and finding out what your electrical system is doing? Starting with the alternator to make sure its putting out the correct voltage and not spiking? Then start checking if you have shorts.
I stuffed both batteries into one tray. Gotta have a properly working electrical system, though.
x2, start with a voltmeter. Put the battery on a trickle charger, then put it back in the truck. If there's a short, the battery will be dead within a few hours or days.
