Corrosioin inhibitor?
Bay Area, CA
I'm putting my mini knuckles on, but it will be a while before I will have the truck rolling. And since the truck is outside, I need to coat my new rotors with something to prevent them from rusting for the next 6-8 months (I work slow! ;-)). I was going to slather plain old grease and a poor-man's shrink wrap of saran wrap on them, but then thought that there might be a good reason to use something specific for corrosion protection, like cosmolene. But it's like $10.00 a can, and if grease will work just as well, I've got plenty of it already. BTW, I'm NOT installing the calipers just yet!
Is there a better way?
Boeshield T-9, available at any boating store, or online. Developed for aircraft storage by Boeing.
I've used it for years for steel stored outside, with excellent results, better than cosmoline, not quite as good as those oily dip waxes.
Comes in spray cans, easy to apply.
Kirk
So, if used in a rotor application, does it affect brake performance, or does it burn off after a couple of stops? Does it wash off with a pressure washer, etc?
Sounds good for vehicles in long term storage.
Ed
And....where do you get it?:bounce2:Nevermind....I re-read the previous posts:doh:
Jesus. Who cares? Leave them as is and the friction will burn off the rust (and hopefully any pitting), or dont install them and put them in the house.
Pinion, I have an old BMW that has been in a machine shed for about 10 years, after the drivetrain was rebuilt and the brakes gone through. I have had it re-done twice due to rust. Yeah, it gets started every month, but that does not help the brakes.
Now go back to yer cave, it is not yet time for you to awaken:flipoff2:
Ed;)
I'll throw in another vote for Boeshield. Also available at woodworking stores, for use on cast iron tabletops.
It just seems like a ridiculous question. If you are worried about it, and the rig obviously isnt going anywhere for half a year, you wont need the brakes, and you're obsessing about it...why leave them on??
:beer:
Now there is an intelligent response.:) Thanks,
Ed
Ok. Then here is another. Every time you are working on your rig, give each un-used rotor a good douche'ing of WD40.
:beer:
You'll have to 'splain that one.:) I don't usually leave my brakes "on"
Ed
Sorry, I meant the rotors. If they werent going to be used, and he's worried about them rusting, its pretty easy to just take them off.
My studs press through the rotor into the hub, so it aint' easy to leave the rotors off. (I want to be able to roll the rig around) Yes, I was a DS when I took the original mini discs off the hubs and scrapped them (they would have been good place-holders for the shiny vented TLCs), but this is my first FJ project, and the last major project since my VW-in-a-basket purchase in 1973, and for some reason (prolly mostly my much-abused old brain), I haven't been able to see every detail of this project as a clear line from start to finish. Yer a lucky fella if you can, Rob.
Oh, BTW, they must have different WD 40 in the east - the stuff out west will last about 3 days as a rust preventer. i WISH I could work on the rig that often.....
