Corroded #6 Injector Connector
supercarrera
Club Esprit de Four
Santa Clara, CA
Website
www.instagram.com
Hi,
Below are pics of my #6 injector. I had a misfire along with code 25 and 26. I'm guessing this might be the problem. Any suggestions on how to proceed? Obviously, I'll clean it up but what all should I replace, if anything? I'm guessing I need to remove the injector? Anybody have the part number for the connector because I think I cracked the lock tab when I was messing around with it?
Thanks!
Where's the coolant coming from - hoses above, or head gasket?
I'm not totally sure but it looks like from above.
Yes - gravity would dictate that.
DougM
Damn gravity! Okay well I pulled all the injectors out and #6 looked really bad. Also broke the #6 connector into about 5 pieces. The question is, while I have them out, should I have them professionally serviced? Or should I just have #6 serviced? Can I just clean them off with gasoline?
Thanks
I'd have them all serviced. Call a few shops and find out where they take them. There will be one shop that does injectors for dozens or hundreds of shops. You can't clean what needs to be cleaned with gasoline.
DougM
Be sure to solder & heat shrink the wires to the injector clips if you have to cut & replace them. I think Napa has the connectors. I don't know if Toyota offers them. Wow, that's a heck of a leak. I'm pretty sure someone in your area can clean & service your injectors. Lots of technology in the bay area. Good luck.
Don's Injector Service
1351 E Taylor St
San Jose, CA 95133
Phone: (408) 280-0636
I found this, but have no idea if there any good.
