Correct Knuckle Bearings?-PIC
Discussion in '40- & 55-Series Tech' started by mikealeus, Feb 28, 2007.
  1. mikealeus
    mikealeus
    577
    Media:
    7
    Albums:
    1
    4
    Feb 15, 2006
    Redding, CA
    Just opened a box containing my new knuckle bearings and they do not look the same as the old ones. Anybody know if these are correct? Same manufacturer (KOYO), I don't have anything to measure them with but the I.D and O.D. appear to be the same.
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,374
    Media:
    17
    Albums:
    1
    726
    Oct 1, 2003
    MN
    Run 'em.
  3. cruiserhead
    cruiserhead
    690
    Jul 26, 2003
    North Jersey
    The Gods have spoken.Looks like they just changed the #.The ones you took out are probably 20+ years old.
  4. Tankota
    Tankota
    388
    May 4, 2006
    Olympia, Washington
    I believe those are the same.
    I have mini truck knuckles and have to use the 30303D bearings which are slightly shorter. The 30303 bearings are too tall and I can't get the knuckle over them. Just an fyi.
  5. Poser
    20,374
    Media:
    17
    Albums:
    1
    726
    Oct 1, 2003
    MN
    Wow.
    Never heard of or experienced that one.
  6. Tankota
    Tankota
    388
    May 4, 2006
    Olympia, Washington
    I'm having second thoughts about the one on the left. Measure it's height (bearing combined with race) and compare to the one on the right. If they are the same then I was right...:cheers: If they are different height then :whoops:
    With the 30303D vs 30303 bearings: I actually experienced the "d" vs "non d" bearing height issue myself a couple years ago. That's how I figured that one out...speaking of which, I need to replace my knuckle bearings:doh: AGAIN!
  7. mikealeus
    mikealeus
    577
    Media:
    7
    Albums:
    1
    4
    Feb 15, 2006
    Redding, CA
    I don't have anything to measure with, but will figure something out and report back here tomorrow nite.
  8. mikealeus
    mikealeus
    577
    Media:
    7
    Albums:
    1
    4
    Feb 15, 2006
    Redding, CA
    I measured
    Well sort of. I put both on a level surface (I used a level to verify) then laid the level across both and was still level. I can see no difference in height with my eye. I'm thinkin they'll be just fine.
