Corner Park light issue
ELK GROVE, CA
Just checking in and wanted to see if anyone here has had any experience with an electrical issue I’m having. I just came back from South Lake Tahoe a week ago and it was snowing hard. My driver side front corner parking light went out when I was still up there and thought it was just a bad bulb. This weekend, I tried replacing the bulb but it’s still not working. The signal light park works though but not the park light. I’ve tried cleaning out the plug and even tried raising up the contacts (just in case) but still nothing. I’ve tried looking for a fuse for the park lights, but the passenger & rear park light works though. Anyone have any ideas what’s wrong or what else I need to check? Greatly appreciate everyone’s input. Thank you
Is the bulb replacing is tested out ok?
Check grounds near the light - I'd remove and inspect them - its common for them to pass the quick visual test but still have poor contact with the body/frame. Also make sure the bulb socket is tight enough to make good contact with the bulb contacts.
