Corner Light Change
Annapolis, MD
Hey folks, I have a 97 LX450 and the parking lights on the corner need changing. Thing is, I cant figure out how to remove the lense. Need help cause this is driving me nuts!!! Thanks.:confused:
unscrew, pul out, swap bulb, replace in reverse order.
give it a man tug.
or search here.....lots of threads with pics.
welcome to the jungle!
you must pull it *forward*
and Welcome to the site!
If you're refering to the side marker lights, I had the same question a few days ago. After reading Slee's right-up I was baffled at why I couldn't find the release pin referred to in his right-up. That's because it's hidden and not a release pin in the since that I was used to seeing. It is basically a male/female type snap-in connector. So..., all you need to do is unscrew the top screw that's under the hood, and grab ahold of the lens assembly and pull the whole thing straight forward with a good amount of force, and the whole lense housing will pop out, when the snap-in connector lets loose.
:beer:
Rookie2
Or you can just bust out the lens like I did... No tools neccessary to change bulbs... :whoops:
