Cooling System
Austin, TX
I've got a cooling system leak somewhere around the waterhouse/thermostat housing on my '76 2f - anyone know how to pinpoint the leak. I've already changed the hoses - but still have scale dripping down onto the water pump and across the block. It only seems to leak at high RPMs - can't get it to do it in the driveway. Any help?
Tucker
Tucker: I would first let a trusty repair shop have your cooling sys. pressure tested. This is a very cheap and easy way to pin point a leak. Most shops can do this for you in a short time. I would also check into replacing the water pump. It sounds like yours is starting to go bad. Often when WPs go bad they will begin to leak thru the weap hole on the side of the pump. (this may be your leak). Makes sense that it does it at higher engine temps. (hi-way speeds), as the waining pump is unable to keep up with the demand. With cooler temps nearing, I'd get it corrected ASAP.
I hope this helps. i just replaced my entire cooilng sys over the course of the summer on the FJ60, so I can feel your pain. GOOD LUCK :cheers:
