Just replaced all 3 VBelts in the 80, put in a new battery, flushed and filled the cooling system...seemed to all go well. After starting the truck today and driving it, it was pouring coolant out of the bottom of the truck faster than I could add it back in...since I don't have a pressure tester here, I took it up to the shop and they pressure tested it...water pump is new (within 300 miles, so I knew it wasn't that)...they found that it was leaking a lot where the t-stat housing meets the block/head, or wherever it meets up...said it was more than likely the gasket that mates the housing to the engine that was bad as it was leaking out pretty steadily from there when they pressure tested the system.
Anyone else had this problem? Of course, that gasket isn't stocked locally, so I had them order it from Toyota and it should be in within a day or two...then they're going to replace it. Anything else I should look for after that point?
Thanks in advance if anyone has any more light they may be able to shed on this problem...or if you think I've really got nothing else to worry about after this repair is done.
I suppose that with really flushing out the cooling system, it may have released some grime and deposits to cause this area to really start leaking more. I had pressure tested the rig with a friend once before about a month ago after the water pump job was done, and we didn't notice that part leaking at all before.
Dave.
Dave.
