97 FZJ80. 140k
This weekend I'll be draining the coolant and getting around to some projects I've been putting off for a while. Finally decided to get motivated because my A/C cut out on hwy 10 just after heading over the Whitewater pass near Palm Springs. It was 113 deg outside so I think the compressor disengaged because I hit whatever that magic coolant temp is. After stopping the engine for a bit, A/C worked fine. I have parts for the following:
New water pump, new blue fan clutch, new thermostat, new belts, new hoses, clean throttle body.
Any other obvious PM that I should do while I have the coolant drained and fan/waterpump out? Anything else I can do to ensure top cooling system performance? Is it normal for the coolant to get that hot when it's 113 out and you're heading uphill over a pass?
Thanks
Thanks
mechanic.
