Cooling system flush
Chino, CA
Noob here, 77 FJ40 w/ stock 2F,
I pulled the radiator to flush it out, but I'd really like to flush the block also. The drain plug on the block is working fine (not clogged). I bought one of the Prestone flush kits, but I'm such a noob I can't figure out where to t-into. Can I get some help on flushing the block, or where to t-in with a flush kit?
I want to flush everything before replacing the t-stat and the water pump.
Thanks,
Sean.
I have not ever installed or used one of those kits, but I have seen the T fitting installed in the jumper hose between the heater valve and the head on more trucks than I can remember right now....
Good luck!
-Steve
Thanks, Steve. That did the trick. I was able to get a much clearer flow that way than with just regular draining and refilling.
I'll need more luck on the t-stat and water pump replacement!
Thanks,
Sean.
