I am starting my way through a coolng system overhaul and I have two questions
1. I punched out a block plug for my block heater (really easy to do once you psych yourself up to purposely knocking a hole in your engine
), and on the back side of the plug as well as inside the block there is a slimy green film/buildup. Not the gray flakes/sludge, but a definite green/yellow coloured film.
The history of the rig is limited to knowing that the PO had the rear heater lines replaced at one point. The coolant in the overflow was red (like the Toyota stuff I bought) with black sludge at the bottom of the tank. When I looked in the rad cap, the coolant there was green. I drained from the block plug first and the stuff that came out was a dark mix of green with some red. It doesn't seem to mix completely
. The coolant from the radiator was greener than the block stuff. Both had sandy stuff in the bottom of the pan.
My pressing question here is: how do I get rid of the green slime inside the block? I will flush and flush and flush, but from the little bit of flushing I did tonight it doesn't seem to move the slime. Other than hiring an army of 2" tall gnomes to run around inside my block with brushes, what do I do?
Question 2: This should be easier. When the heater control valve is set all the way to cold, where does the coolant that would be flowing through there flow? There must be some sort of bypass, anyone know where? Just curious.
2.5: Which way does coolant flow in the PHH? Out from the block, or into the block?
Thanks
Thanks
