I read the FAQ and I have an FSM. I did my PHH and Thermostat yesterday. When going to fill the coolant up the FSM basically says Fill, Run, Check Level, Fill. I put 3 gals of fluid in between the radiator and overflow. I was expecting to add more after running the vehicle but the level has not dropped (I've driven about 10 miles since I filled it back up). Are there air bubbles left or am I ok?
This may be unrelated, but It doesn't seem like there is hot air coming from the vents inside. Would I see symptoms from my heating system if I had bubbles in my cooling system?
How can I get rid of the bubbles, I don't want to have to buy and install something extra to do this (not until I get back to Cincinnati at least). Should I just let it run while going on a steep incline?
