Coolant tube identification help
Pensacola, Fl.
The PO obviously bypassed these coolant tubes. Are these going to the rear heat blower that is located under the pass. seat? And why would someone bypass them?
He bypassed the engine too! :eek:
Some people bypass the rear heater because the hard lines rust out and leak on them. Some people do it as a preventive measure as the rear heater doesn't do a ton in these anyway (I rarely use it).
You might want to flush out both heater cores, or at least try to. That new looking hose that connects the input and output was put in as a "quick and dirty fix". If bypassing rear heater, it's better to remove the old rear heater metal "T"s in the line and replace with new, proper length heater hose. I don't think you'll need the rear heater much in Florida, although I'd definitely make sure front heater is working. Also, while the engine is out, I'd take the opportunity to remove those rear heater pipes, if you decide to "retire" the rear heater. They are near impossible to remove once engine is in place.
Thanks for posting, I will check them to see their condition and try to flush everything. I would like to replace them if necessary. This rig is originally from Detroit and the chassis is very rusty. So they may be rotten.
