coolant temp gets cold
My 91 80 loses heat on long downhills.The thermostat will get up to normal temperature when i climb up hill .Then as i go downhill it loses all its heat and blows cold air.Temperatre gauge goes all the way back down = no heat.It will do this even after being driven for a couple of hours.I have replaced thermostat and that did not fix.
Sounds like the thermostat.. Do you have your temp gauge modded or an aftermarket one installed? My 80 was doing the same thing and the Stat was stuck open.
X2
Sounds like a thermostat stuck open. Pull your thermostat and check it in a pot of water. Make sure it opens/closes at the right temp.
I have replaced thermostat twice with o.e.m.I thought maybe i got a bad one from toyota.I also replaced fan clutch .I cant think of what else it could be .I dont want to keep throwing parts at it.Anyone have any other ideas of what it could be.
Do you have a gauge to measure the coolant temp? Maybe the heater valve is not letting any coolant in the heater cores?
Where do you live? If you are in an extremely cold environment, you may have to take measures above and beyond stock to maintain heat.
-Spike
When you changed the T stat did you put the rubber gasket in that goes on top of the T stat under the top of the housing ? Most people dont know about it and if it was missing before you ever opened it from a PO work then you wont know it was gone .
Yup.
Indeed sounds like a missing O-ring on top of the T-stat.
Flush your cooling system. The heater cores may be partially clogged.
I will check for o-ring.I dont remember there being one.Thanks for the tip .I dont think it is a clogged heater core because when temperature is up on gauge it does blow hot.
I'm betting O-Ring
