Coolant leak
Hi,
When I got home from from work tonight, I found steam rolling out of the vent under the windshield. There is also small (3" diameter) pool of coolant on the floor of the garage. The steam is not in the engine compartment, and there is no odor of coolant in the interior of the vehicle. There is no steam under the hood, it only comes out of the vents.
The coolant reservoir was full two weeks ago (drained and replaced in Dec) an now the reservoir is empty.
My first thought was head gasket, but the up side is that there is no oil in the coolant and no coolant in the oil. I can't smell coolant in the exhaust coming out of the tailpipe.
My second thought was heater core, but I can't smell it inside the vehicle, so that seems like a good indication that it probably isn't that. Isn't the heater setup inside the vehicle under the dash, venting into the pass compartment? Last time I had a heater core leak it smelled very strongly of coolant inside the vehicle (bmw 325).
My third thought (I'm in salt country) was rear heater lines. I dug around in the FSM and can't find the rear heater lines anywhere. Can someone point me to where they are routed? I know landtank said they run up above the tranny - but do they pass through that compartment below the windshield?
I need to go out and poke around, but I wanted to get an idea in my head of where the rear lines are routed first.
Any advice would be welcome.
Thanks,
Charlie
I think you got 2 things going that aren't related. Your steam out of your windshield vent is water from the weather in there being heated up by your rig - otherwise you'd smell coolant inside. That's the intake for your heater/AC exterior air. I'd guess the coolant puddle is from either your PHH or your rear heater lines. You'll need to crawl under your rig with a flashlight and find where it's dripping from. Sorry, no shortcuts on that one. As for location of these, if you look on this link, it might help. Just scroll down to the heater hose & PHH sections. HTH!
We have a winner - PHH. Wow, nice work 80t0ylc!!!
It went from drip to stream as I was under the rig trying to locate the source. Glad it happened at home, not in the middle of nowhere. I have the hose and clamps in the back of the 80. I guess I know what I'm doing tonight...
Thanks!
Not such a bad job after all. Cramped, messy, and not a lot of fun. Pesky sums it up. 1:20 including cleanup. I had the hose and clamps in the emergency kit (plain old gates heater hose, not the fancy silicon stuff). Definitely not a job for the side of the road. The second time will be easier without that pin type clamp...
Glad you nailed it - good work! Yup, it's pesky. X2 about side - of - the - road. Best to do that one in the comfort of a garage - or at least in your driveway this time of year.
Edit: That is one thing that I think is great about this forum. I was able to diagnose when my PHH was seeping, before it blew on the road, from help on MUD. Neat that I could return the favor to someone. Thanks for the update!
