coolant leak
Have an 84 4runner with a 22r. As I was driving the car began to run hot an smelled coolant burning, I discovered coolant leaking from passenger side area under the air filter/carburetor and above the starter. I thought it might be the hose that is in between this area, but after replacing, discovered that I still had a leak right above the hose. I am not able to locate what is under the carb and leaking. When the engine is idling, it begins to drip, and drips faster as the car warms up. Does anybody have any ideas of where this leak is coming from? Any help would be appreciated. Thanks
If its getting a heavier, quicker drip as its warmer than it is metal of some sort, as metal expands when its hot. I dont know, nor at the current moment have the will power to grab a flash light ad examine mine. So ill look and get some ideas 2morrow. till then, cheers
This is where the dental mirror comes in handy.
