coolant leak
Coolant collecting on top of water pump housing . Important? Had Head gasket replaced about 5,000 miles agp.
Yes. You have developed a leak.
Odds are you also got a new radiator cap at the same time, so your pressures have increased a tick. Is it on the t-stat housing or the water pump housing? If T-Stat, it's the O-Rings in the down pipe. If the water pump, IDK because the weep hole is on the bottom unless the pulley is slinging it up and over.
