Coolant issues
Funny you mention the semi rough idle since I just started getting that yesterday.
It's confirmed. I'm leaking fluid from the radiator area. GRRRRRRRRRRR!
I'm praying that it's just a lose hose or something and not the radiator itself.
Back under the car I go. ;(
In trying to go home from work, the truck didnt start. I put water in it this morning and so I checked it again when it didnt start. Radiator empty but overflow tank had fluid? I put some water in the radiator and it started up. Coincidence? I looked underneath and saw some water dripping. Couldn't see clearly but I think it was coming from where I pointed to on the picture below at the joint of the two rusty tubes. Should there even be coolant/water coming out of there?
I also checked my oil dipstick and oil cap. Oil looks ok but there is a little slightly yellow residue on a little bit of the dipstick and the same residue on the underside of the oil cap. What would that possibly be caused by? (Hoping not to hear "blown head gasket")
Water coming out of the exhaust flange and residue on the cap/dipstick is pretty much a bad sign. Do you do really short runs in this car? This can cause condensation inside the engine but I doubt enough to leak from the exhaust, time to get a compression check and a coolant sniffer to check for combustion gasses.
regards
Dave
Hi Dave,
Me and some buddies did a compression test like 2 months ago. If I recall correctly, values were 170ish-180ish.
I do currently right now do semi-short runs with the truck. I work 6.9 miles from work, but because of traffic, its about a 25 min drive.
I took out the overflow tank yesterday night to clean it since it was dirty and reddish inside. It did smell oily/gassy.
When you say bad sign, is it pointing towards head gasket issue or something else?
Hi Dave,
I did not find a response to post #19, is your car an automatic?
The compression test unless carried out very carefully the results can be pretty much pointless unless of course there is a big hole somewhere. If you have a small leak perhaps at the head gasket a few things tend to happen, the cooling system gets pressurised and looses some water, when the engine is switched off the prssure in the cooling system forces water back into the leaky chamber, when you restart the water gets blown into the exhaust where it gets heated up and becomes white steam, on coolant recovery systems such as yours the system needs to be air tight, in the early stages of head gasket failure the water coninues to be sucked back from the reservoir as the engine cools, as the gasket gets worse water starts getting left behind in the reservoir because there is no longer a vacuum in the cooling system, water does not always get into the oil but more often the other way around because of the pressure differential, although it can happen if the hole is big enough, eventually the car overheats within a few minutes as the coolant is boiled away or the engine runs so bad it become undriveable, if you fill the cooling system and start the engine and the idle is a little rough try pulling off plug leads until you locate the weak cylinder/s, this is where the clean spark plugs will be found.
I would do the folowing in this order:
Fill the radiator and start the engine with the cap off, lots of bubbles or surges with the engine idling?
If your car is auto check the auto fluid and perhaps temporarily disconnect the auto cooler pipes and join them together, if the radiator A/T cooler is leaking you will now get water out of the open pipes you have left in the rad when the engine is running.
If no issues here or your car is manual then move on to a coolant 'sniffer' and get your coolant 'sniffed' for combustion gases.
Take out all the spark plugs keeping them in order and side by side, compare them with each other, normally a small amount of water getting into the combustion chamber leaves the chamber and plugs clean.
If this is still inconclusive then perhaps a leak down test is in order?
regards
Dave
Thanks Dave. Its an auto. Will try to read what you wrote and soak it in (noob here).
I'm renting a room in LA right now and dont have space to work on cars, nor any tools. I will be taking it to Jim Dickey on Saturday and hopefully he can help. I'm just hoping she will be ok until I get home to San Jose. Then its going to be playing around with her until shes good.
Dip the auto trans fluid, no tools needed and it will take one off the list. Safe journey home and I hope you get there without to much trouble, keep stopping and adding coolant to keep damage to a minimum.
regards
Dave
Is there just a dipstick I can check for the tranny fluid?
Will do that tomorrow morning. If there is bubbles/surges, what is that an indication of?
Thanks,
John
Looked at the tranny dipstick, looked normal and was reddish-pinkish. Not sure what I should be looking for.
As for as starting it with the radiator cap off, there was some bubbles coming up. Wasn't like alot but it was trickling up. Should there be no bubbles at all?
The transmission fluid should look like red wine, clear and obviously red. If it is pink, brown it is suspect unless of course you have some trick transmission fluid in there in which case it may be BLUE. If you are unsure of the correct colour go and buy a small bottle and compare?
The bubbles should stop once the system has purged air after a refill.
regards
Dave
