coolant flush gone bad - quick question
Boulder, CO
I have recently changed out the phh and and done a flush of the cooling system on my 97 cruiser. After finishing, I started the truck, and it began puking coolant out of the rear heater tubes, right above the front catalytic converter. I am going to bypass those heater pipes altogether, and run heater hose to the rear heater as many have suggested in other posts, securing the new hose to the frame via zip ties, as that sounds like the best solution.
My question is, can I do this without losing all of the brand new and pricey Toyota red coolant that the truck is still full of? As the truck sits in the driveway, it's not leaking, however as soon as I start the truck it begins to leak. I will drain the coolant and buy new if I have to, but if there's a way to keep all or most of the coolant from leaking out then I'd like to go that route. Please advise, and thanks in advance.
-Justin
Drain the coolant from the radiator and block and catch as much as you can. You shouldn't need to flush the system again, so whatever coolant stays in the system should be fine. Fix your leaking rear heater tubes, then refill with your saved mixture. You'll no doubt need to top off, since you undoubted lost some coolant, but you can premix more Toyota red and distilled water at the same ratio you used when you initially refilled the system and use that for topping off.
yup, should be fine to reuse, I would think. I would suggest to refill it through a filter though and take a peek at any sediment or particle, besides just not putting it back in.
coffee filter would do for filter medium. If you don't reuse, expect to lose about 1.5 gallons. Curious what year is your 80? Mine leaked right above the cat on the 94LC which I did this summer . I think this has to do more with metal brackets abrading the lines rather than Midwestern salting of the roads. Most of the hard lines on my 88LC leaked behind metal brackets.
I was hoping that maybe there would be enough suction in the system somehow that I would only lose a small amount, and that I wouldn't have to actually drain coolant from the block or the radiator. I am guessing I'm wrong. That being said, I'll have the buckets ready, and the coffee filters too, although I think the bottom of my truck is dirty enough I'm probably just going to do another flush and fill at this point. Straining 3+ gallons of coolant / distilled water mix through coffee filters doesn't sound like that much fun.
archie - I saw a post or two from you regarding this same issue. Did you end up just bypassing the heater pipes directly and do as I plan with new heater hose? If so, how has it held up.
Thanks again for all the replies.
held up well. I did the bypass, cut off metal tubing right before it turns horizontal (that way you can push the hose around the metal tube) and cut off the rubber where it enters the floor boards. Think of the way you will push the hose onto the metal tube before you cut because it might be hard to put on if you cut the metal tube at the wrong place. You'll probably have a little water based lubricant to help from the PHH job, so that will help. What year was your 80?
My 80 is a 97 40th. It's quite clean underneath, and I was surprised to see how bad these heater pipes looked when I crawled underneath. I have been thinking of where exactly I wanted to cut the heater pipes for ease of installing the new hose. Do you have any pics of where you cut the heater pipes Archie? Also, did you use standard 5/8" inner diameter heater hose or 16mm?
I don't have any pics . Just find a place where a Dremel like cutting tool will work easily with the provided space. I cut my metal lines before it turns horizontal towards the cats. I think I used 1/2 inch hose(as reccomended on another thread), it was tight fitting, but snug and not too difficult to push on the metal pipes.
I think you're right about the where to cut the pipes, Archie. I have to check one more time to make sure that the leak is NOT coming from above that bend before I go cutting anything up. I'm pretty sure that the leak is right at that first bend or further to the rear of the truck possibly. I'm headed to the auto parts store to pick up the goods after work, and hope to have this completed this evening. Thanks again.
Your welcome! I would cut it and let it drain for a few hours before tackling it. Draining the system is the pain. The dryer it is , the better the working conditions.IF wet and dripping, the cut-off tool tends to spray coolant everywhere if it's still wet and it get all over you eyes and hopefully not your lungs. Cut or drill drain holes on the bottom of the line near the bend so coolant does not atomize when cut above with a fast moving cut-ooff wheel. If you are using a reciprocating saw, stabilize the sections to be cut to prevent shaking the lines and vibration damage. I tried small plumbers hand cut off wheels, like the ones they use on copper pipes, but found that the rusty uneven surface of the lines made it difficult. The Dremel like tool was the best, but be careful, even though it's very small, it'll cut you're fingers off with the wrong moves. It has torque and can bind. If it falls don't try to catch it and allow an escape route for your face when laying underneath. Use eye protection, at least from the coolant.
